'88 4x4 3vz manual *Transfer Case fluid* ... is castrol syntec gl-5 okay?
Main question is about the Transfer Case:
I put in Castrol Syntec SAE 75-90 full synthetic gear oil...(similar found here black bottle, red banner at the top ...and I've had a case of it for years but finally used it in my front/rear diffs and transfer case.
fwiw the (manual) transmission got redline MT-90 and I have a quart of it left over.
The point here is if that oil is okay for the 1988 transfer case?
It only says gl-5 on the back where it states :..."performance that far surpass conventional API GL-5 and MT-1 gear oil."
bottle states :
Fully synthetic, API GL-5 and MT-1, SAE 75W-90 formula.
SAE J2360 (MIL-L-210SE) approved.
meets and exceeds conventional and synthetic gl-5 gear oils.
Friction modified for use in both convential and synthetic axles.
However, I've recently read that maybe *some* transfer cases will have syncros and I don't know if mine does or doesn't...or if the transfer case has brass in it and if so, if this oil is okay or not for brass?
Before I spend any more money I'd like to know these things.
please and thank you.
bottle states :
pruney81
Aug 4, 2010 08:26 AM
Gf8er
Nov 24, 2009 05:55 PM
runethechamp
11
Oct 19, 2005 08:27 PM
