Hey y'all, middle of doing the Weber swap on my 22R. I bought the plug and plate kit from LCE and things have been going smoothly (no broken bolts) I finally got the air injection tubes off but I don't see what plate I'm supposed to use to block off what looks like is in the lower part of the intake. Is this plate made? Did I order the wrong kit? Or do I just have to make my own? On the exhaust manifold side I got those two plates bolted up but it's the intake side I'm wondering about. Here's a picture of that the end of the tube that meets up with the intake looks like.
EDIT: Yes I did try Google and I did try and search the forums but all I keep finding is info on the exhaust side or the tubes look completely different than mine.
Have you had any luck with this issue? I'm going through the same thing and google isn't showing anything for that specific block plate
