P0172 issue only at idle!
Old Aug 18, 2021 | 11:18 AM
Granulated_sugar's Avatar
I just bought a 99 4runner limited 4wd with the 6 cylinder motor. I bought it knowing it had a CEL and a coolant leak. I replaced the water pump and that fixed the coolant leak but now I'm trying to track down this CEL. The code is p0172 (bank 1 rich) and I have already tried diagnosing a lot of things.
I checked all real time sensor outputs and it looks like my long term fuel trim is incredibly negative. The only other thing that may seem a little concerning is the maf output is a little high ( 3.3-4.7 g/s ).
Anyways, I started with the basics. I replaced the plugs, wires, and coils. This helped but didn't fix it. Then I cleaned the MAF sensor and replace the bank 1 sensor 1 o2 sensor. This also helped but didn't fix the CEL. I then removed all the fuel injectors and cleaned them - they all seemed to spray pretty well and held pressure without any leaks (not sure if this did anything).
After doing all this, the CEL still comes on with high negative long term fuel trims. The strangest thing is that it only runs rough at idle. As soon as I start driving and putting the engine under load, it seems fine. The CEL is only ever triggered at idle. The other thing to note is that acceleration is smooth and powerful and gas mileage isn't very good at all.
Anybody have any insights?
Old Aug 18, 2021 | 04:22 PM
wyoming9's Avatar
Any issue with long cranking times??
Miles?/
Have you checked the injectors ? You might have one or more stuck open
That would account for the poor fuel mileage Just what are the real numbers?
As long as mine does not drop below 9 miles per gallon I am happy (3.4 5 speed)
Old Aug 18, 2021 | 05:03 PM
I pulled the injectors and sprayed carb/throttle body cleaner through them all. They all held pressure without leaks (this was no official test and the pressure was only momentary).
Old Aug 19, 2021 | 06:37 AM
wyoming9's Avatar
Red face
Just how much pressure does spraying from a spray can give you.??
Just curious Well it was a thought.
I am sure you will get it figured out!
Old Dec 27, 2023 | 01:05 PM
Remc's Avatar
Hello I am having a very similar issue with all of the same symptoms on my 1998 3.4l T-100, I was wondering if this issue was ever resolved? If so, please let me know so I can try to get my rig back on the road. Thank you!
BajaRunner
Mar 9, 2011 01:35 PM
JBSTRD
22
Aug 6, 2010 09:45 AM
nawty
Jan 23, 2010 11:51 PM
brian2sun
26
Sep 30, 2009 11:31 AM
