2wd headers for 3.0
Old Mar 11, 2021 | 07:14 AM
suparuuged's Avatar
2wd headers for 3.0
Any one knows if there are any headers for a 2wd 1990 3.0 long tube but doubt it at least shortys?
Old Mar 11, 2021 | 07:21 AM
MaK92-4RnR's Avatar
Pretty sure the only reason that companies claim that the headers only fit 4WD trucks is because of the crossover. You shouldn't have an issue putting the headers on and just reworking the crossover a little bit.
Old Mar 11, 2021 | 09:33 AM
suparuuged's Avatar
thank you for your quick reply, so as far the fitting it in they should bolt up hopefully they fit between the frame and the steering shaft nicely and from the flange to the cross over some modding will be made.. which is no problem. But as long as the LT headers fit .. btw I am currently building a
Toyota 3VZE 3.0L V6 Engine Hi-Pro 190HP/210ftlbs
From raptor engine.. has anyone heard or used this motor before.. trying to get headers for this when I drop in the motor..
Old Mar 11, 2021 | 09:55 AM
MaK92-4RnR's Avatar
Frame should be the same. The only thing difference is that your truck doesn't have the front differential, cv joints, front driveshaft and no transfercase.
I've heard of the engine before but there hasn't been too much information about longevity posted on this forum. There's a few threads that mention it, if you use the search bar.
Personally, I'd rather 3.4 swap it for the money.
stevennc
Jun 17, 2017 04:19 PM
Ninja 85
Sep 13, 2010 11:38 AM
Ilovemountains
Jan 22, 2010 07:04 AM
needsomecam
Feb 22, 2009 07:16 PM
DirtCheap
Mar 12, 2006 06:51 PM
