1988 Runner 3.0L Automatic to Manual Conversion
Hey Ya'll,
I just bought an '88 Runner that has a bad automatic transmission. I want to switch to a manual. The engine I currently have is a V6 3.0L. My question is: What parts and pieces will I need to purchase alongside the manual 3.0L V6 trans to make the smooth transition happen?
Thanks,
Thanks,
You will need the manual pedal assembly. Master and slave clutch assembly.
Hydrolic like that goes between the master and the slave. Hard line and soft line or you can just use a long soft line.
clutch fork, throw out bearing, clutch kit flywheel.
Proper bolts for the flywheel.
manual drive shafts. I’m not 100% sure if you need these but you might.
speedo cable may be different as well.
90 ventwindow
Jan 15, 2012 02:12 PM
nakatsuj
Jul 27, 2005 05:13 PM
yotamaniac
May 24, 2005 05:03 AM
