85 Toyota gas tank fix
Hawdy yall. New here first post! Ok I got a big problem lol. My gas tank was leaking so I pull it. Well i got the leak fixed. Well at least I thought I did lol. Anyway truck started right up but still had a leak. Found out it was on top of the tank. The pump hangers return line had 2 holes. Pretty bad leak! Ok fixed that and hooked everything back up and it would not start. Looked around and the positive wire broke off. So I need help and just quick fix! Thank you.
For about 150 USD you can get a new pump bracket.
For about half of this you can get a rivet tool and the other stuff to repair it.
For about a quarter of that you can just put a new non proprietary bulkhead connector in its place and switch to ring terminals.
pcmentor
Sep 19, 2008 04:05 PM
