85 Toyota gas tank fix
Old Jul 30, 2020 | 05:12 PM
Hotrod85's Avatar
Hawdy yall. New here first post! Ok I got a big problem lol. My gas tank was leaking so I pull it. Well i got the leak fixed. Well at least I thought I did lol. Anyway truck started right up but still had a leak. Found out it was on top of the tank. The pump hangers return line had 2 holes. Pretty bad leak! Ok fixed that and hooked everything back up and it would not start. Looked around and the positive wire broke off. So I need help and just quick fix! Thank you.
Old Aug 1, 2020 | 07:34 AM
se7enine's Avatar
It's time to replace that whole assembly for the fuel pump.
Old Aug 1, 2020 | 07:51 PM
muddpigg's Avatar
Drill it out and re-rivet. Can braze your seal.
Old Aug 6, 2020 | 11:35 AM
Co_94_PU's Avatar
For about 150 USD you can get a new pump bracket.
For about half of this you can get a rivet tool and the other stuff to repair it.
For about a quarter of that you can just put a new non proprietary bulkhead connector in its place and switch to ring terminals.
artemyk
Apr 1, 2018 11:50 AM
edgar62902
7
Jun 6, 2013 06:12 PM
Bearhunter75
Apr 15, 2013 09:53 PM
pcmentor
Sep 19, 2008 04:05 PM
jon_7248
Nov 22, 2006 08:52 PM
