Orientation of clutch disc for 3VZ?
Old Mar 12, 2020 | 03:49 PM
68jimmy's Avatar
All,
I've searched and so far haven't found a definitive answer as to which direction the spring side of the clutch disc should face? The failed clutch disc I removed was stamped on the non-spring side to face the flywheel, so the spring side is facing the transmission. I came across a tech note on Yotashop.com (https://www.yotashop.com/blog/clutch...on-guidelines/) that notes for the 5VZ the spring side should face the flywheel. I'm making an assumption that it would be the same for the 3VZ, but I'm not sure.
The new AISIN clutch kit I purchased did not come with any instructions and the disc is not stamped to indicate which side should face the flywheel. Any is greatly appreciated!
Thanks,
d.
Old Mar 12, 2020 | 05:25 PM
68jimmy's Avatar
I ran another search using google and came across this thread, https://www.yotatech.com/forums/f16/...-3-slow-56431/ which supports the old clutch disc orientation. I'll go with this unless someone can point me to something different. For reference, I'm attaching pics of my new disc along with pages from an FSM I found on Marlin Crawler which seems to show the spring-side facing the trans although it doesn't state it.
Thanks.
Spring side facing up
Spring side
Old Mar 13, 2020 | 04:21 AM
wallytoo's Avatar
probably go with how the old one was oriented.
my 88 VZN FSM shows that as the correct orientation:
Page CL-4 Installation of Clutch Unit
diagram clearly shows raised portion facing transmission, flatter side towards flywheel.
Old Mar 13, 2020 | 04:26 AM
old87yota's Avatar
Originally Posted by wallytoo
from the yotashop link you posted:
seems pretty clear.
Their post doesn't mention the 3VZ-E.......
Edit: I just noticed your edited post.
Old Mar 13, 2020 | 06:30 AM
68jimmy's Avatar
I thought that was weird as well, however I believe all they do are 5VZ swaps so it may be why...
Thanks!
d.
Old Mar 13, 2020 | 04:18 PM
Jimkola's Avatar
YT Community Team
5 Year Member
I've always thought the general rule was flat side was up against the flywheel, the thicker side towards the transmission. Though I wouldn't be surprised to find exceptions to a perceived rule.
Old Mar 13, 2020 | 04:31 PM
68jimmy's Avatar
According to yotatech.com and some other information I found the 5VZ is opposite. flat side towards the trans...
d.
Old Mar 13, 2020 | 06:21 PM
Jimkola's Avatar
YT Community Team
5 Year Member
It sure looks like on the 5vz does go fat side to flywheel. Good thing others researched.
wakkjobb
3.4 Swaps
Oct 30, 2016 07:17 AM
KBar
Jul 7, 2013 06:50 PM
BumbleYota
Dec 23, 2012 03:43 PM
94yota05gto
Sep 19, 2008 02:20 AM
Tigerstripe40
Aug 4, 2006 04:38 AM
