89'-95' Toyota Pickup Build Questions
Old Mar 1, 2020 | 08:54 AM
Gregg Leaverton's Avatar
Toyota pickup 89'-95' 2WD
Questions:
1.
Is there an upper control arm (UCA) on the market that will increase wheel travel?
2.
I'm a little confused about wheels. I know I need a 5x4.5 lug pattern, but I do not know about center bore diameter, backspacing, and the rest. If someone could fill me in as to what the best wheel is for 31x10.5xR15 tires, I'd appreciate it.
I like the pre runner look, and this truck will be a single cab 2 wheel drive vehicle.
Thank you for your time and consideration.
Sincerely,
Gregg leaverton
Old Mar 1, 2020 | 09:42 AM
tyvanwie's Avatar
Is there anything wrong with your current wheels? If not, I'd just throw bigger tires on them and call it a day.
Old Mar 1, 2020 | 01:02 PM
Bump, I haven't gotten an answer yet
Old Mar 1, 2020 | 01:08 PM
If no one can or will answer my question about rims/tires
I'm open to other suggestions about what to do with the Toyota pickup, or things that I should go over. I'm pretty firm on my decision to get the Toyota pickup now, I know it's been a bit of a back and forth between it, and a Baja bug and other vehicles. Last was a DRZ400, something that gets 11+ inches of travel out of the box stock and over 50mpg ect... (That idea was a bit hard to let go of)
But now I'm firm on the Toyota pickup and will be hopefully making my purchase soon. Can't wait to go camping
Advice? Pointers? Suggestions? - should I eBay brand linex my entire truck? Primer grey? -- any advice on paint? Suspension?
Should I buy the spark plugs wires and all that or drive it tell the engine breaks and then fix everything that's then easier to get to??
Is it better to get a vehicle with 200k Miles or 220k Miles with a rebuilt engine?
Thanks
Old Mar 1, 2020 | 01:18 PM
tyvanwie's Avatar
So you haven't even bought it yet? Lol
Old Mar 1, 2020 | 01:43 PM
Not yet,
Advice?
.will next week
Old Mar 1, 2020 | 02:53 PM
tyvanwie's Avatar
Originally Posted by Gregg Leaverton
Not yet,
Advice?
.will next week
Here ya go ^
Old Mar 1, 2020 | 02:59 PM
I'd like bigger wheels/tires for looks and ground clearance
Old Mar 1, 2020 | 03:08 PM
tyvanwie's Avatar
Bigger wheels have no effect on ground clearance, but if you want them for looks then go ahead. All you need is you standard 5x4.5 as far as I know. Nothing special needed. For 31s I recommend at least 4" backspacing. 3.75 would be good for when you lift.
Old Mar 1, 2020 | 03:15 PM
Bigger wheels have no effect on ground clearance? Did I mean tires?
The differential sits low, adding bigger tires sits it up higher.
I don't understand why the backspacing needs to change for when there's a lift?
Old Mar 1, 2020 | 03:21 PM
tyvanwie's Avatar
Bigger tires effect ground clearance, wheels do not. Lift typically means more suspension travel, especially with solid rear axles. At full bump, a smaller backspacing w(3.75"k) the tires from rubbing the inner fender by pushing the wheels farther out, especially turning at bump. If you're doing a prerunner build, the fiberglass fenders and bedsides should have adequate space to accommodate the backspacing.
And i i dont think I'll be doing a lift just bigger tires 31's
Old Mar 1, 2020 | 03:36 PM
No backspacing is required for just larger tires ? (not a long travel Build)
I mean you say you need backspacing for a lift, is this just for a larger tire lift or a long travel lift?
HachiRokuEight6
Mar 1, 2020 02:27 PM
Sportsmanphil
Mar 8, 2011 06:39 AM
kwikrnu
Jan 7, 2007 01:50 PM
dr3wstar
Jan 22, 2005 11:29 AM
