Who do you trust for part numbers
Bought an 85 truck and am working on accumulating parts, like a front main seal.
Different sources, yotashop, amazon, toyotapartsdeal, etc., are giving different part numbers for the front main seal. I do know the difference between the T type premium and the normal one.
I like to be able to accumulate my part numbers and then just order by numbers when I am ready. But, with different part numbers and them showing as correct depending on the site, it makes it hard.
Example: Front seal
yotatech: 90311-45069
yotatech: 90311-45002
Toyotapartsdeal: 90311-45014 Supersession(s): 90311-45014; 9031145006; 9031145011
I'm sure I'm confusing the situation by not taking something into account.
So, who do you trust for part #'s.
Example: Front seal
You can search the correct parts for your specific frame number here: :https://toyota-usa.epc-data.com/
It's an RN60s frame.
Side question, does toyota use the same part with many different part numbers. For instance, on the front main seal, would it be likely that all the front seals for a 22re are the same actual seal, even with different part numbers? Except the short seal of cours, which moves the location of the sealing ring.
With this SKF Master seal list, you can find the SKF number that crosses to any Toyota seal number. Then, you might find any other manufacturers number by cross reference. There is a similar list for bearings: :http://www.absbearings.com/uploads/1...cat-457012.pdf
kooter77
Apr 16, 2021 10:59 AM
Swede
Aug 28, 2010 04:18 PM
DrummerDaveB
Dec 11, 2006 09:57 AM
