tps replacment question
Old Oct 13, 2019 | 11:13 AM
keycw's Avatar
5 Year Member
still need to test my TPS to confirm, but I believe it needs replacing. my question is, when you install a new TPS (oem) do they require a "baseline" adjustment from Toyota are are they just drop in?
Old Oct 13, 2019 | 11:41 AM
millball's Avatar
They do require a' baseline' adjustment. In fact, it is the ONLY adjustment that can be made to a TPS.
All the multitude of tests the FSM shows for a TPS are only to determine if a used TPS is fit for further service.
The TPS, new, or used; must be adjusted so that it sends a 'throttle closed' signal with the throttle closed, and that that signal stops when the throttle is opened ever so slightly.
Many seem to fixate on the other tests as if any adjustment might change them. It cannot.
Old Oct 13, 2019 | 11:43 AM
keycw's Avatar
5 Year Member
thanks
stomper4x4
Sep 28, 2010 11:29 AM
joehill
Jan 25, 2009 10:04 AM
JohnStra
Jan 30, 2007 05:37 AM
lesha30
Oct 4, 2004 11:36 AM
lesha30
Feb 29, 2004 01:04 PM
