Hilux/hiace transmission info needed
Howdy y'all! I'm looking for some information regarding the Hilux engine/transmission combos. Well I guess hiace too since that's what I'm building! . I have a 92 hiace super custom with he 3L enigne/G52 5 speed transmission and I'm looking to a vw alh conversion. Theres a company thst sells adapter plates for the alh to Toyota gearbox (either the w56 or r150 transmission) and I'm wondering which plate will work with my G52 trans. I know the Hilux came with the 3L as well, but did they also have the G52 gearbox? The Hilux also came with the w56 box but I'm not sure if the 3L would bolt up to that. Any inform would be greatly appreciated!
Here's the adapter plate I'm looking at:
W56
https://www.dieselconversion.com/adapter-plate-toyota-w56-to-1998-2002-vw-1-9-tdi.html
R150
https://www.dieselconversion.com/vw-alh-and-ahu-to-toyota-r150-adapter-plate-includes-cranshaft-spacer.html
Which one would work with the G52?
I'm aware that the G52 is not the same number as either the w or r transmission, but I was told that the G and W series have interchangeable bellhousings
W56
R150
I wanna see the hiace, man! Pics?
Checked quickly on marlin crawlers board. Seems you need the W56 adapter. https://board.marlincrawler.com/index.php?topic=756.0
But that 52 is supposedly weaker - you think it will be ok with the torque of the TDI? I would think the R150f would be the much better choice. But you'd need a new transmission.
It's hard to see but there's an engine mount thing on top of the trans
My 07 tacoma at burnstick lake
My strength info is from Marlins board.
In the low RPMs torque is more "damaging" than when the stuff is spinning fast.
I'Ve never broken anything not in first gear.
So I guess if you start of slow and only give it full power in second after it's moving you'll be ok.
Scofco
43
Feb 14, 2005 05:09 PM
