FS[PacNorWest]: FS: 1993 4Runner 5-Speed 3.0 - Turn-key rig
Old Aug 27, 2019 | 08:59 AM
aa1911's Avatar
$4,500 OBO
The good:
1993 4Runner 4x4, V6 3.0 Motor (original) runs good, still reliable, 174k on the clock. Title in hand, ready to go. Pearl Grey color, paint is in good shape, one area fading on roof. NW vehicle, frame/chassis is in good shape with only minimal rust present.
5 Speed Manual Transmission
Custom seat covers (cordura/marine vinyl centers with pockets on back of seats, faded)
BFG A/T tires (32's) (old) on Cragar Soft 8 Steel wheels (16") - 5 matching tires/wheels with moderate wear only
Towing package, AC, Power Windows w/Driver Auto down, Sunroof, Roof rack (Yakima Rack)
Glass is all intact, battery is 1 year old, ready to drive. Regular maintenance since purchased in 2008.
ISR mod, intake is simplified, cone filter
HID w/ projectors retrofit headlights, 4k color temp
Starter just replaced
Alternator replaced new in 2008
GAS MILEAGE: I run 91/92 octane in all my yotas, with that it will still hang onto 15-16mpg's reliably with mixed city/highway driving
Interior is in good shape, minor cosmetic blemishes only. Has good floormats.
Timing belt and all other belts changed at 155,000
Auxiliary wiring harness added, has power outlets in rear and voltmeter, also is wired for on board air
LED lights all around
The Bad:
AC needs recharged or system swapped to 134a, does not blow cold air anymore.
Rear Window quit working for a brief period, tore it down and tested everything, and it started working again, seems to have been solved. But it counts as an electrical gremlin in my book. Key still works reliable on rear window.
Tires are fairly old, would recommend off road or low speeds only
Very minor dents in rear bumper/corner, some sun damage to front corners of roof area
Stock cassette/AM/FM radio only
Exhaust should be redone soon, it's starting to rust through on the downstream end
Driver door key lock is worn; I do have an aftermarket keyless entry/alarm system but only has one key fob, I removed it; it does have power locks. Pass door, rear tailgate and ignition all work well with key, no issues.
I'm selling because I purchased a new Tacoma and cannot afford to feed and maintain 4 Yotas, one has to go. This is a decent daily driver or dedicated off road rig.
Message me if interested or if you wish to see additional pictures or want extra information.
Thanks!!
AA
Old Aug 27, 2019 | 09:06 AM
aa1911's Avatar
Voltmeter/ outlets in rear pass side
Also has U bolts for tie -downs in back, extra LED lights inside the rear area
Old Aug 27, 2019 | 09:09 AM
aa1911's Avatar
Seat cover rear pockets, also has horizontal zipper to access stock seat back pocket. Built from 1050d cordura and marine waterproof vinyl centers. I redid the centers a few years ago but the grey portion is faded a bit but still very functional.
Last edited by aa1911; Aug 27, 2019 at 04:11 PM. Reason: 1050d ballistic cordura, not 1000d
Old Aug 27, 2019 | 09:20 AM
aa1911's Avatar
Actual location is near Yelm, WA 98597, should have added that up front
space-junk
813
Nov 18, 2021 09:00 AM
4RunnerMN
May 22, 2011 06:06 AM
AaronW
Apr 19, 2007 05:33 PM
