Can bad brake booster cause soft / spongy pedal?
Hi all,
I've replaced everything in the brake system except the booster, lines, and lsvp.
My pedal still goes to the floor, all the way down, to really brake. It does brake, just all the way down, feels like air, but I've bled the damn thing plenty of times. Yes, I bench bled the MC and have bled it all correctly. When bleeding brakes and press down pedal completely, idle goes down. From what I understand that may be normal.
Is it possible that the booster is bad and causing this? Any way to check / test before I order one?
Hi all,
I've never heard of anyone trying to bleed brakes while the vacuum assist is active (engine running), you should probably try that in "the normal way" without the boost.
If you get air in the bleed tube keep pumping, it's not bled yet. Any of the connectors could be leaking from the bleed valve all the way back to the cylinder. Leaking bleed cocks are pretty common.
There have been a few instances of upside down calipers, or bleeders installed in the wrong position (they are supposed to be the higher location).
PS. If you have oversized and/or heavy tires it doesn't help.
31s but i'm pedal to metal every time to come to a stop
Is the pedal soft and spongy or just have a lot of travel? If it has a lot of travel and the brakes work you may need to adjust the rear brakes. You can also test the booster by pressing the pedal with the engine off and starting the engine. If the pedal goes down it is most likely working.
Anybody have input to my original question? Can a brake booster, even hypothetically, make your brake spongy / lot of travel?
Lots of travel, and soft. What's the difference? It travels a lot till it begins braking, then it brakes ok, but softly. It can fully lock up, but hardly, and after pressing all the way down. When the truck is off, it takes a couple pumps for the pedal to be rigid. Then, turn on the engine, and the pedal sinks.
There was a good point above regarding the travel. You don't get pedal pressure untill there is resistance pushing back against the pads. Pop the inspection port open on the rears and check the resting position of the pads (spec is in the FSM, from memory its something like two or three MM)
Update?
I know this is super old but I have the exact same symptoms as you (albeit on a completely different vehicle). Have also changed MC, flex lines, calipers, cycled the ABS module, bled the systems soooo many times. Did you ever figure out what your culprit was? I’ve been leaning towards my issue being the brake booster but it’s a huge pain to replace so I’d like more confidence that’s my problem.
From: exo-reality -wave if you see me; Front Range, CO
brake issue
Anyway there is also a proceedure in FSM (don't have in front of me) to check and adjust the pedal freeplay and travel. Thats probably a good place to start at this point.
Good luck
Trevor Mohler
Apr 29, 2019 07:06 AM
some drunk guy
Jan 15, 2014 07:31 AM
