Fuel pump running but no fuel?
Old May 18, 2019 | 04:41 PM
Maeson Yosick's Avatar
I took off the bed of my truck hooked up a clear vinyl tube to the fuel line, jumped the diagnosis box and ran the pump. Nothing came out, is it possible to install the fuel pump backwards? I even added gas thinking maybe there wasn't enough.
Old May 18, 2019 | 06:03 PM
old87yota's Avatar
If the wires were hooked up backwards, the fuel pump will run backwards.
I would check the wiring and see if the pump will draw fuel into the tank through the vinyl tube.
Old May 18, 2019 | 07:44 PM
Co_94_PU's Avatar
Pretty sure the check valve and vane shape will prevent this..
It's either wired backwards, the I tank filter is plugged, or the bypass is wide open (pretty sure even then some should get through).
Old May 18, 2019 | 08:53 PM
old87yota's Avatar
I forgot about the check valve....
sam_KOR
Sep 25, 2016 09:14 AM
ktreece
Aug 15, 2013 02:48 PM
Shawnjames
Jul 24, 2013 10:08 PM
komh98
May 3, 2009 06:18 PM
ozziesironmanoffroad
Nov 6, 2008 06:38 PM
