84 22r Toyota pickup 4x4 firing issues
so I have a 84 Toyota 4x4 pickup the truck will not fire with the ignition switch but will bump start fine. I just built the motor and have replaced the battery the alternator and regulator along with distributor and have done a hei gm conversion and the ignition switch. It has to be bump started. I’m getting 12v to the coil. Just for the info I did the hei gm conversion due to thinking the original stock ignitor was bad. I have no idea where to go from here or what to try to get it to fire I have run a hot wire directly to the coil with absolutely no change any help would be amazing!
tlucyk
Mar 29, 2011 07:21 AM
