Toyota anti freeze
Color isn't the issue. Whether or not it contains silicates, borates, phosphates, and other *ates is.
Look for something which specifically states that it does not contain the various *ates. While they cool better, they are abrasives and have a tendency to erode water pump seals quickly. Prestone 5/150 and Havoline Extended life are suitable.
Use distilled water in the mix.
The current rule out there for coolants is a simple one. Use and continue to use what came in it from the factory.
Those "orange" long life coolants are only true long life coolants if they where the first and only coolant used in that cooling system. They use organic acid tech and the way they benifit your engine is that induce a chemical reaction to the surface of the metals which is kind simular to a protect corrosion layer. Sounds odd I know, but it can not do that if it was not the first stuff in there.
Still to this day I can not understand why anyone would want to use something other then what came in there engine. True the off the shelf green stuff, which is fine for your Toyota is cheaper then the Asian Red Toyota stuff, but how often do you flush your cooling system? I do mine every 30,000 and I just do not see how saving $5 every 30,000 is something to really worry about.
Just use what came in it.
Gadget
Gadget
i don't have the slightest clue what came in my engine. 25 years is a long time ago! it just says not to use alcohol based coolant in the owner's manual.
however when rebuild time comes around(e.g. when i get a job again) i'll fill her up with some toyota red
Green is what came in your truck. That is the only stuff that used to be available before all this "proprietary" crap came along. Asian Red (Toyota) is compatable with all green systems and is supposed to be a higher quality coolant.
So, is that true, you have not changed your coolant in 25 years???
Gadget
Gadget
Gadget
Gadget
Originally Posted by boogyman
i could've sworn i saw a post somewhere that said there was no difference between the red toyota coolant and the high life green stuff... i can't really refute anything though cause i don't know where that post was..
It is generally the same stuff. There maybe more or less of certain ingreadiants. One may have less silicats and other bad stuff then the other. Both are however interchangable.
Check the lable for the ingreadients and chemical break down as to how much or what is in its make up.
I know one thing for sure, the Toyota brand Red has a an additive to help make leaks stand out and eaiser to find.
Gadget
Gadget
I can't remember where this came from but it does show major differences.
I always wanted to know if anyone has used red coolant and still had repeat hg problems.
I'd post the chart but it says the file is to large, any smaller and you can't read it.
What to do.
What to do.
Gadget
Gadget
What to do.
What to do.
Originally Posted by kyle_22r
don't forget, never, ever, EVER use orange dexcool unless it's required for your vehicle. it turns to sludge and blocks your water jackets.
To help it's case a little, I think a majority of the problems are from owner neglect. However, I wouldn't ever trust leaving the same anti-freeze in my rig for 100,000 miles without changing it.
Another antifreeze option
Gadget
Gadget
http://www.evanscooling.com/html/npgPls.htm
