Tailgate hinge pin
Old Jan 12, 2019 | 11:00 AM
NYHumpinUtah's Avatar
Tailgate hinge pin
Has anyone ever rebuilt the tailgate hinge pins? It seems the hinge in welded to the tailgate one one side and the other side bolts to the bad. The problem is the pin is worn out and moves quite a bit in the hinge. The pin however is "swedged" in the hinge. How does one go about fixing it?
See pics.
Just trying to get rid of all the slop in the hinge but I don't see an easy solution other then grinding the swedge off of one side.
Old Jan 24, 2019 | 05:38 PM
Nobody has fixed this? Really?
Old Jan 24, 2019 | 06:22 PM
old87yota's Avatar
I have never touched mine, they still work just fine.
Old Jan 24, 2019 | 06:39 PM
Mine have about a 1/4" of play!
Old Jan 25, 2019 | 01:07 PM
thefishguy77's Avatar
Is it right to left or up and down play? Not sure what difference it makes. Just asking.
Old Jan 25, 2019 | 01:23 PM
Yeah, right, left, up, down,
all of above, that's the reason I want to fix it
Old Jan 26, 2019 | 04:07 AM
jazz1's Avatar
5 Year Member
Looks like you would have to heat the swedged area to pound it out as it looks very heavy duty to pound cold. I would trim it off with die grinder. Would also possibly resize the hinge holes if they are worn. With luck its just the pin thats worn and replacing it will remove the slack.
Xoloski
Oct 29, 2018 01:32 PM
seabee 86
Oct 29, 2018 09:23 AM
Seans4Runner
Apr 19, 2009 11:32 AM
Howdy
Feb 8, 2007 08:42 AM
Ultraformat
Nov 9, 2004 11:01 PM
