86 2wd Xtra can body on 86 4x4 single cab
I have an 86 4x4 single cab with a beat up body and bought an 86 2wd Xtra can with a good body. If I put the whole radiator support and front clip/cab on will the front body mounts line up?, I plan on welding the new body mounts on the rear, I have a flatbed so the back body doesn't matter also plan on installing a 3" body lift to clear the gas tank. Any tips or advice would be appreciated
you will probably run into some clearance issue with the 2WD tunnel on the transmission and T/C.
but with that huge ass 3" BL you may be good to go..other than having to work with the shift lever clearance etc in the holes
Cason Shoemaker
Apr 16, 2019 05:42 AM
mrfrank707
Apr 25, 2011 04:37 PM
15.50_STOCK
Jun 8, 2008 10:01 AM
rdlsz24
May 26, 2008 04:29 PM
slisdexia
15
May 12, 2008 10:55 PM
