86 2wd Xtra can body on 86 4x4 single cab
Old Jul 5, 2018 | 02:02 PM
colbygilchrist's Avatar
I have an 86 4x4 single cab with a beat up body and bought an 86 2wd Xtra can with a good body. If I put the whole radiator support and front clip/cab on will the front body mounts line up?, I plan on welding the new body mounts on the rear, I have a flatbed so the back body doesn't matter also plan on installing a 3" body lift to clear the gas tank. Any tips or advice would be appreciated
Old Jul 5, 2018 | 02:16 PM
dropzone's Avatar
Fossilized
you will probably run into some clearance issue with the 2WD tunnel on the transmission and T/C.
but with that huge ass 3" BL you may be good to go..other than having to work with the shift lever clearance etc in the holes
Old Jul 7, 2018 | 12:09 AM
wyoming9's Avatar
Red face
If you can Fabricate you will make it work .
It has been some time but the front mounts might be the only ones that don`t need moved .
Old Jul 7, 2018 | 12:16 PM
Just got the truck home today pics will follow I took some measurements and it looks like the bed was in better shape than I thought, it may get bobbed as well
Cason Shoemaker
Apr 16, 2019 05:42 AM
mrfrank707
Apr 25, 2011 04:37 PM
15.50_STOCK
Jun 8, 2008 10:01 AM
rdlsz24
May 26, 2008 04:29 PM
slisdexia
15
May 12, 2008 10:55 PM
