Head bolt stripped during installation, redo right?
Old Jun 9, 2018 | 08:37 PM
Bobobigdog's Avatar
Details: 3VZE on a 88’ 4Runner
So I stripped the #3 bolt on the right head, the last 90 degree turn didn’t feel nearly as tight. I checked, not even 75ft-lbs. Is the block stripped or the bolt? The other head went on perfect.
I think the right thing to do is take the head off, investigate the block/bolt, replace gasket and bolts. Right?
Thanks people.
Old Jun 9, 2018 | 08:41 PM
Bakervaper's Avatar
Will the bolt get tight at all or as you tighten the bolt and you start to feel resistance it becomes loose?
Old Jun 9, 2018 | 08:45 PM
Bobobigdog's Avatar
As I pulled that last quarter turn it just felt like lower resistance, it is about 65 ft-lbs I’ll have to check that tomorrow morning. I checked the other bolts and 75 ft-lbs doesn’t budge any of them.
Old Jun 9, 2018 | 09:10 PM
Bakervaper's Avatar
Did you tap the threads? As crucial as head bolt torque is if it were me and i doubted the integrity of the block threads I'd tear it apart and verify the problem however if it's not obvious that its stripped maybe the thread were dirty
Spanky.Rodriguez
Dec 30, 2013 02:14 PM
cheappc
Apr 18, 2013 02:44 PM
manyyotaman
Nov 30, 2009 03:18 PM
sjlrunner
May 27, 2009 05:30 PM
shanesanders
May 6, 2009 05:08 PM
