91 3VZE Power steering
My old power steering pump was making some noises, so I threw in a re-manufactured pump from NAPA. Used ATF like the manual says. The pump worked fine for a few days, but the first time I went on the highway (60+ mph) after the replacement, the power steering stopped working. A few minutes after exiting the highway, power steering came back. It happens every time without fail, and power steering usually comes back between 2-15 minutes after highway driving. Any thoughts? Thanks!
When you say the Power steering stops I am guessing no belt slipping making a squealing noise . Correct ??
The truck steers like the Power steering belt has been removed ?
If every thing is installed correct sounds like your rebuilt is not assembled correct
Without being up close and in person just a good guess
Yeah, I flushed and replaced the ATF and bled out the air. The fluid level has not changed since the day I installed it. It works flawlessly around town, but as soon as I hit the highway it goes kaput.
lmddmc
Oct 9, 2014 11:42 PM
rydholm11211
Jul 4, 2013 04:45 PM
CDUFF7
Oct 31, 2006 07:06 PM
