Clutch/tranny/transfer case HELP
Old Jan 20, 2018 | 11:47 AM
ruby66's Avatar
1991 4x4 22 re 5spd truck is new to me any way drove about 30 miles to junkyard on the way back had trouble getting it into 1st pulled over then couldn't get into any gear tried moving transfer case now i can't disegage 4 whl drive put fluid in the clutch reservoir I can get it in gear but it's binding up help
Old Jan 20, 2018 | 11:55 AM
wyoming9's Avatar
Red face
Was the Clutch Master cylinder empty ??
If it was empty it will need bled .
Did you find out where it was leaking??
If one or the other has failed it will not allow the clutch to work
Old Jan 20, 2018 | 01:15 PM
ruby66's Avatar
it was close to empty can you tell me how to bleed it
Old Jan 21, 2018 | 01:33 AM
wyoming9's Avatar
Red face
Maybe someone close to you could help ??
First just where did all the fluid go ??
It has to be leaking someplace.
There is a bleeder valve on the slave cylinder .
Some people just use gravity making sure the Master does not go empty.
With a helper have them push the clutch to pressure is built
Crack the bleeder valve while the clutch is not allowed to raise off the floor.
Repeat as needed
Old Jan 22, 2018 | 06:34 PM
ruby66's Avatar
Repeat as needed
Got it home ordered the slave cylinder hope the rain stops long enough to get it in thanks for the advice
live4soccer7
Nov 28, 2011 08:24 AM
4wheelingyota
Aug 30, 2010 04:45 AM
91Toyota
9
Jan 3, 2009 02:24 AM
bamarunner
Jul 20, 2003 03:12 PM
