Cold start injector switch repair with pics
Old Dec 17, 2017 | 06:43 PM
zerohedspace's Avatar
So this was pretty fun.
My cold start injector switch was busted and it was starting to get cold here in upper middle northern south Ontario. Some soldering skills required, little dexterity, some small files and decent hobby vice.
last pic I used a candle to help dry my jb weld. still holding tight, -20C last night and she fires right up.
I am suffering from power lag
Attached Thumbnails Cold start injector switch repair with pics-cold-start-injector-switch-repair-001.jpg   Cold start injector switch repair with pics-cold-start-injector-switch-repair-002.jpg   Cold start injector switch repair with pics-cold-start-injector-switch-repair-003.jpg   Cold start injector switch repair with pics-cold-start-injector-switch-repair-004.jpg   Cold start injector switch repair with pics-cold-start-injector-switch-repair-005.jpg
Cold start injector switch repair with pics-cold-start-injector-switch-repair-006.jpg   Cold start injector switch repair with pics-cold-start-injector-switch-repair-007.jpg
Old Dec 17, 2017 | 06:47 PM
millball's Avatar
Great job!! There's great satisfaction in repairing stuff that others would just throw away.
Old Dec 17, 2017 | 07:00 PM
Melrose 4r's Avatar
5 Year Member
X2. Nothing to lose if it's broken already. Might as well try a fix.
what happened to cause it not to work? Did it suffer blunt force trauma?
Old Dec 17, 2017 | 07:49 PM
lol yes, i believe it did receive blunt force trauma from a previous owner.
Old Dec 17, 2017 | 07:53 PM
RAD4Runner's Avatar
Great job! Was it a broken wire?
BTW, I'd also like to take this opportunity to remind fellow members of one thing that is often overlooked when working with the CSI system.
The CSI timer switch gets ground from the engine block through the threads on its mounting port. If the threads are not clean, scaled or IF insulating material like Teflon tape is used, CSI timer switch would not get ground and prevent the system from working.
I used battery terminal brush to clean mine down to bare, shiny metal:
Old Dec 17, 2017 | 08:08 PM
muddpigg's Avatar
Cool, fix!
Old Dec 20, 2017 | 01:44 PM
@millball yup, there really is. specially when the damn part is $160! lol
@RAD4Runner Thanks! yeah there are two brass tabs that run from the inside of the body to the connector, PO must of smashed it off some how. was tricky not shaking the soldering iron in there.
Thanks muddpigg.
hermyboy3000
Nov 9, 2020 04:31 PM
Ramiz09
Oct 12, 2016 04:02 PM
4Hummer
Dec 24, 2013 07:34 AM
lewisaricl
Dec 4, 2010 05:08 PM
Jay
Oct 11, 2004 08:06 PM
