1994 pickup 4x4 22re rear brake shoes
Hi Need to replace my oem rear shoes on my 94 pickup 4x4 ,still running the oem factory shoes . What do u guys recommend for replacement toyota oem or other brands such as raybestos,wagner ,or ??? What the best place online to order the oem toyota shoes ...thks for the help
I don't know about your model but on our first-gen 4Runner OEM brake shoes have been discontinued. I am perfectly happy with the $17/pair shoes and $16each rear cylinders from NAPA. If it would help your decision, very little braking power is provided by rear brakes; most of the braking is done by fronts.
Also, just a heads-up: I suggest you make sure you have readily-available brake cylinders or rebuild supplies and tools, just in case. If you still have the original shoes, deteriorated brake fluid, and rusted/pitted brake cylinders may cause a leak. Why it happens explained here: https://www.yotatech.com/forums/f116...l#post52373259
Don`t forget Drums as well
I like the Napa Ultra Premium Line of brake parts
It seems doing the rear brakes can be an adventure at least here in the Northeast .
Don`t forget to back the adjuster off to get the drums off easier
Making sure once things are apart the adjusters are cleaned and lubed working like they should
I picked up a set of shoes from Autozone for $17 gonna put those on for now till i save up for one of those complete kits shoes,cyls,drums, springs..they were cheap enough to play with will post a pic soon thks
scott.475
Jan 28, 2007 08:47 AM
