My GF drove my truck and now..
You d never guess.. It drives better than before!!
Basically she screwed up starting it with her foot on the gas all the way and said it revved like "craaaaaazy" for a few seconds. Very Scary like a beast she said
Now I notice at 60mph I cruise around 2600rpm, before I was closer to 2900... Did she serve it an Italian tune-up?
It just does not work like that
Engine and road speed are a function of the gear ratios (tires, differential, transmission). You are possibly remembering incorrectly, something is loose (like your tach signal), or was loose (like your transmission solenoid connectors).
Get a gear ratio calculator and run your equipment specs. This will tell you where the rpms should be for a given road speed.
I laughed when I first read this story, but my thinking was along the lines of Co_94_PU.
If you're 300 rpm lower at the same speed, it means your girlfriend got you some bigger tires and you didn't notice (unlikely), or differentials with a lower gear ratio (who knows, maybe she wrenches and wanted your truck to get better fuel economy on the highway?) Either of those changes would cause a noticeable drop in power.
You could swap in a 500 hp big block v8 but if you kept your old tires, gears, t-case and transmission you'd be in the same rpm at 65 mph in 5th gear as you were with a 22re. More power will make engine rpm and moving speed increase faster, but always together.
If your numbers are right, you're a very lucky man because after the guilt of blowing up your engine she: changed your diffs overnight and completed some major engine work (stroked crank, h-beam rods, forged pistons, arp studs, over-sized valves, port work and a mild rv cam). Oh wait, I'm projecting my own dream again... you're actually suffering from wishful thinking.
