water[ coolant] coming from timing chain cover
Old Oct 5, 2017 | 08:39 AM
glassbysam's Avatar
1994 toyota pickup. 22RE emgine jut installed remanned engine 2500 miles ago
How can coolant [water] be leaking from timing chain cover? could it be leaking from head gasket and going into the timing chain cover?
thanks in advance
Old Oct 5, 2017 | 08:42 AM
irab88's Avatar
VW Bugs are air-cooled, there shouldn't be any coolant anywhere.
Old Oct 5, 2017 | 10:17 AM
gsp4life's Avatar
The water pump is on the timing cover. Can you tell where it's leaking from? Run the engine with the hood open and pull the throttle cable to rev the engine. Should spray or drip out faster and you'll know right where it's coming from.
Old Oct 5, 2017 | 11:03 AM
irab88's Avatar
Ah! It's a 22R-E...
Also check the water pump. Sometimes those can have a bad seal/gasket.
Old Oct 5, 2017 | 11:09 AM
gsp4life's Avatar
Originally Posted by irab88
Ah! It's a 22R-E...
I figured you'd just smoked something or other. I was kinda jealous!
Old Oct 5, 2017 | 11:21 AM
irab88's Avatar
Nah, OP just said his engine was leaking coolant without stating what engine he had. I just assumed it was a VW Bug!
Anyway, to help out with the leak:
https://www.yotatech.com/forums/f116...l#post51705070
This is from when I did my front-end rebuild. There is a coolant pipe that goes under the exhaust; check around there. It tends to not seal if not torqued properly.
