Hello Everyone. I Bought a 1989 Toyota Pickup (22RE, M/T) that was in an accident, and long story short, I'm having trouble finding the A/C parts I need. I have scoured the web and had no luck finding them anywhere. I need parts 7 and 8 in the attached diagram. Can anyone steer me in the right direction? Thanks.
It looks like part 6 is available, but depending on your (engine? model?) part 7 is discontinued. More information would be required; pick up the phone and call them (have your VIN ready).
So you may end up fabricating a line. The trick is the funny crimp on the end to seat the o-ring. I'm sure there is a tool to do that (you could look for a big A/C shop in your area, to see if they can make lines). Or you can use universal "you bend 'em" line. http://www.vintageair.com/2013catalo...ebpgs%2077.pdf
Sorry, forgot to mention that info. It's an '89 SR5, 22RE with manual trans.
What I did for the suction line #7 was to purchase line #6 And cut it. It has the 2 ends you need. 2 ac compression fittings and some no 6 ac hose. worked great. I may be able to post a pic or 2 if you want
