1993 V6 4x4 4runner with A340H Auto Trans will not shift past 2nd Gear
Hey whatsup guys, currently the truck is not throwing any codes but I went ahead and replaced the shift solenoids anyways.
The truck hard-shifts from 1-2 every time but from 2-3 I have only successfully hard shifted it 2 times and have tried numerous times since without success.
When in drive the transmission attempts to shift into the 3rd but the engine just disengages, like a valve is stuck?
When I replaced the solenoids I forgot the clean/replace the filter, do you believe that a clogged filter could change the valve pressure enough to not allow it to shift?
Thanks guys
Thanks guys
