Working on my headgasket and chain/guides look good so i dont plan on pulling t-cover. Will i still need to pull radiator, belts? Or can i make it happen like that?
I agree with Millball, however its not a bad idea to have the rad professionaly cleaned depending on the reason for the head gasket failure and the length of time it has failed
When you get ready to put it back together don't make the same mistake I made when I did my head gasket on my 22R. Clean you head bolt threads in the crakcase so you get a proper torque on your head gasket bolts. I didn't do this and blew my head gasket again. Everything was flat and true, so it had to be bad torquing of the head.
Few more questions. I have the exhaust side out now and working on the intake, does it unbolt from the head all in one peice or does it have to come all appart (throttle body, injectors, etc)?
You have to pull the upper intake plenum then pull your fuel rail and lower intake plenum. Pretty sure you can leave the throttle body on. Pretty sure there are some coolant lines that need to be taken off after you pull the upper plenum off, but it's been awhile. Should be pretty self explanatory once you take the upper plenum off though
Intake almost all out yay. I notice a bit of slack on my timing chain against the driver side guide, normal right? Just making sure my tensioner isnt bad
All going good so far before and after cleanup (razor, brake cleaner, and emery paper) pics. #2 piston has coolant traces in it, also shows on valves obviously
Good idea on the zip ties. I usually take the cam gear off and use a long screw driver or extension through the chain. Make sure when you put it back together you use FIPG or rtv equivalent in the spots on gaskets where you are supposed to otherwise it won't seal properly
Yes fairly fresh, guides are good etc, no leaks, why mess with it now when i can do it in 50k miles
I tried changing the timing chain without removing the head, dinged the head gasket while installing the timing chain cover and had to replace the head gasket. Head gasket/timing chain R&R done at the same time is a reasonable approach.
