I dun goofed and forgot to take a picture of my alternator wiring before I took it off, and now I'm pretty convinced it's f-ed up. In the image below, the bottom left terminal, next to the plastic connector, is the 10 or 12 gauge + wire. I had disconnected the yellow condenser wire at some point, so I'm not sure I put that back correctly either. There is also a black wire with a ring terminal that comes out of the same bundle as the other alternator wiring...does that go on the "e" terminal on the right side of the plastic connector? I have the FSM and a toyota 20r repair manual and the setup they show is completely different. The truck was pretty hacked up when I got it so I'm not sure what's been replaced or cut up.
For what it's worth, I had the black ring terminal hooked up as a chassis ground, on the heater hose retainer bolt next to my ignitor, and I'm getting all sorts of wacky stuff going on. I had a surging, uneven idle with a random misfire, and I shocked myself pretty good by just touching a bare metal spot on the fender where the paint had rubbed off :/
So the battery wire goes to B? That makes a lot of sense :p
I may have overstated my knowledge, what I meant is that I can't really tell what the wiring diagram is showing. There doesn't seem to be anywhere else for the black wire (not pictured) to go, except the alternator.
Thanks for the help y'all, I'm okay with mechanical stuff but electronics is voodoo magic as far as I'm concerned
Hmm that link is still missing the other wire, the black one. Could it be something related to the charging light? Attached to the same terminal as the battery wire?
As mentioned in the link, and shown in the OP's first post. That's the neutral wire between the regulator and alternator. Or it wouldn't be electrocuting them.
Here is the wiring diagram, let me know if you need to see a different section of it as well.
And the black wire, I hooked it around a random terminal to keep it in the picture. It's part of the same bundle as the battery wire and the connector for the alternator.
So if it is the neutral wire between the regulator and alternator, which terminal would I need to attach it to?
