Carb Sight glass
Carb Sight glass
How much fuel should you see in the sight glass before you attempt to start a stock 22r with OEM Asin carb? Mine reads way below half before I attempt to start. I usually have to hit it with a shot of ether before it will fire if it's been sitting for a day or so. I know it could use a rebuild, but just trying to eliminate other potential issues before I start throwing parts at it.
My float level was set to see half a glass of fuel. With that setting, I would do one pump with throttle and it would start right up. Make sure your accelerator pump is working good
Thanks!! I'll check the accelerator pump, and give you an update. I figured it should be at least half full.
Yup. Just pulled it off the other day. I'll let you know my findings once I bolt it back on.
