To start off I lost blinkers all together. I did have emergency flashers but no other blinkers working. Still had head and tail lights, brake lights. So I was thinking combo switch went bad sense check fuse and ground and found them all to be ok. So was set to order the combo switch.
Then on my way home last night I lost all lights. Head and tail lights, brake lights, still no blinkers and dash lights. I mean nothing worked. Emergency flashers did so I limbed home.
Any ideas or help on what could have first caused no blinkers (don't know if combo switch all together went out or even if controls everything listed that not working)??? It would make sense except for the brakes lights not working? Any help would be great!
I was driving along then turned steering wheel into Burger King and everything quiet working. I wish I had a better idea Of what causes it. Is there a main fuses that would control all of this things? The brakes lights, head and tail lights along with dash lights stop working all at once.
The switch combo maybe the cause of the blinkers not working as I traced it back to under the dash then nothing through the wiring harness. Both problems maybe different. Cant get get another truck got to much blood , sweet and tears in this. Lol that truck use to be white. Has 40000 org. Miles on it.
Update: I found out why all the lights went out. Loose wires got wrapped around sterling shaft so when I turned I pulling those wires out. So fixed all that have all lights back now but still don't have a blinkers.
Emergency blinkers yes but not regular blinkers. I found combo switch at u pull it for cheap. Replaced and still nothing. I am lost as to where to go from here. Have ground, no fusses blowed! Is there any other relay or anything that could be causeing the blinkers only not to work? Again any help would be great!
