Standard Cab Short Bed 4x2 vs 4x4 Fuel Tank Swap?
Old Sep 5, 2016 | 12:06 PM
Thomas Reynolds's Avatar
I'm researching swapping over from a 22R to 22RE. I'm about to buy a salvaged 4x4 short bed standard cab 22RE truck. I understand that the tanks have to be swapped for in tank vs out of tank fuel pump (and anti starve pump design). However I've noticed looking at brochures that while my 2wd standard cab short bed RN80 has a 13.7 gallon tank the RN101 4wd standard cab short bed had a 17.2 gallon tank? Will I be able to swap in the 17.2? I could see a difference in a long bed design or xtra cab, but essentially aren't these the same frame with a different suspension/transmission? I can't find where someone has commented on any forum why this swap would or wouldn't work. What could be in the way under there? From pictures online the tank is a little longer but no wider.
http://ecat.spectrapremium.com/prod/TO9B
http://ecat.spectrapremium.com/prod/TO10B
Old Sep 5, 2016 | 07:11 PM
Robert m's Avatar
The bigger tank will hang down lower too
Old Sep 21, 2016 | 05:28 PM
But will it fit?
Old Sep 22, 2016 | 12:13 AM
wyoming9's Avatar
Since I never saw a 2wd truck up close and personal .
Measure your truck the clearance you have side to side front to back.
Cross members that support the tank distance
Can you fabricate and move things as needed ??
hard to measure something you don`t have in front of you
Is the fuel fill the same spot on both beds ??
This would seem to be most important unless you want to install a new fuel fill location every thing else can be adjusted
What tank is called for in the 22re application for your truck.
Why not go with a outside the tank electric pump of the proper pressure and flow rate ??
Then some new lines and filter your good to go.
Old Nov 3, 2016 | 07:17 AM
Gizler00's Avatar
The 4x4 tank is about 10" longer. There is a different crossmember location on the 2wd frame as opposed to the 4wd.
Check out out my thread "build for a buddy" in the 84-85 section. I have some pictures on this.
Joey22r
Feb 27, 2016 04:24 PM
Joey22r
Feb 23, 2016 10:16 PM
teahmahn
Feb 10, 2016 12:14 AM
jbaums
Feb 10, 2016 12:07 AM
localfiremedic
Jan 31, 2016 07:16 AM
