1985 w/35"s Brake pedal hard w/minimal stopping power AFTER...
I have a 1985 4x4 pick up with 35" mudders (25% tread fronts , 10% - bald rears). Proportioning valve is zip locked in the up position, which I understand will make the back brakes work more than normal as if I had a heavy load. The brakes worked fine other than occasionally the rears locking up, if I tried stopping too fast, due to the two factors that I mentioned above. My dilemma is I slammed on my brakes to avoid hitting a deer and now the brake pedal is hard and I have minimal stopping power. I should add that I have the driveline style emergency brake so I can't check the rear brakes by pulling the e-cable. Any ideas would be appreciated, thanks !
Thanks for the response. It fixed itself sorta speak... I took it for a test drive and pushed down a little harder than I wanted to, in fear of breaking something, but I needed to stop and as I was pushing down something popped and the brakes were back to normal. I'm guessing it might have been one of the cylinders stuck... ?
you need to consider doing a brake upgrade. the stock brakes were designed for 225/15/75 pizza cutters.
when i went to 35's on my 81 i converted to Vented FJ rotors, V6 IFS calipers it was night and day improvement.'
I through in a dual diaphragm brake booster out of a turbo truck with a 1" bore master cylinder. I could stop on a dime. best bang for the brake mods you can do on a SA toy truck, well that and high steer to get rid of the crappy push pull steering
