4Runner in limp mode pls Help
Old Aug 14, 2016 | 04:28 AM
adam0281's Avatar
HI I have a 1992 4Runner 3.0l 5 speed the other morning started up but would rev over 2000rmp The computer is giving 3 trouble code 21 24 32 i replaced the afm and o2
Old Aug 14, 2016 | 06:51 AM
fierohink's Avatar
Did you reset the ECU?
Does it too out at 2000rpm in neutral or when driving?
When was the last time it ran well? Did anything happen between then and now? Parts get wet? Fuel up (possibly bad gas)? Run really low on gas?
Old Aug 14, 2016 | 01:08 PM
scope103's Avatar
I know you're posting this from a phone, but it's important to include all the WORDS or we don't know what you're saying.
First, it's not in "limp" mode (that's a feature of code 52). Second, code 21 is a fault in the O2 sensor heater CIRCUIT. It doesn't hurt to replace the O2 sensor, but there's a good chance that your problem is actually in the harness (which is exposed under the truck). Get out your multimeter and check voltages: http://web.archive.org/web/201003261...01heatedox.pdf
I assume you had all three codes, replaced the O2 sensor and the VAF on a whim, and still have the same three codes. Codes 24 and 32 point to unrelated systems; the only thing they have in common is the CONNECTOR. Check that. And in case you didn't figure it out already:
I'm going to guess there was nothing wrong with your VAF anyway (how much did you pay for the replacement?), so check it too:
http://web.archive.org/web/201003261...92volumeai.pdf
YOTAHILLBILLY
Sep 26, 2016 01:31 PM
Conleyfry
Mar 12, 2016 07:02 PM
HappyAdventure
Feb 20, 2016 06:32 PM
Kj94runner
Jan 27, 2016 12:01 AM
Robinhood150
Jun 15, 2002 12:58 PM
