88 4Runner keeps blowing clutch masters
Hey guys, so I got a 88 Toyota 4 runner and the previous owners says it has a " 90 3.0 engine and tranny" but I'm not 100%. My problem is that I keep having clutch master problems. The clutch master blew last Friday and The first 2 that got ordered in as a replacement, the push rod wasn't long enough. So the pedal would be really close to the floor. Then I ordered a clutch master out of a 92 pickup and it fit perfectly and felt amazing. Then 160km later the seal blew and it started leaking fluid into my carpet again. I'm not stomping on the pedal by any means. Any help would be greatly appreciated.
Are you buying Aisin Hydraulic Parts??
While changing out all these failed Master Cylinders have you looked that the bracket is not cracked or the bolts have come loose??
Other then parts packaged wrong .
Cheap China built Master Cylinders
