Toyota 8" U Bolt Flip Kit from RUFFSTUFF!
This kit will replace the stock U-bolt assembly in a spring under, or spring over setup with Round Bend U-bolts giving you not only more ground clearance, but also pointing the threads away from the rocks you drive over which can make them impossible to remove without cutting.
These, like all of our U-bolt kits feature 3/8” thick Top plates, each with three available holes for the center-pin, which when used with our spring perches gives you the ability to move your axle forward or backward an inch very easily.
The U bolts are a 5/8” fine thread, Grade 8 rod that we bend in house, and they all come with not only extra-thick flat washers, but also Grade 8 tall-nuts that have ~ 75% more thread engagement than a standard nut.
One thing to keep in mind is that the stock configuration mounts the shock to the original U bolt plate, which means that you will need to come up with a new way to mount the shocks to the axle.
XtremeOff-Road
16
Jun 27, 2002 07:32 PM
