Possible newbie gear question
In the process of deciding which gears I want for my rig. I'm thinking 5:29 just because I love low gears. My question is, can I use my stock third member that currently has 410 gears and replace the ring and pinion with the 529? Just covering my bases before I get this all done.
^x2
Youll need a new crush washer, which should come in a bearing/install kit. Or its a great time to switch to a solid pinion spacer. Tad harder to set up, but wont loosen over time. Good time to add a locker too, you know, while youre in there.
http://www.4x4wire.com/toyota/tech/crush_sleeve/
TG sells the solid spacers
Stuarrt
Apr 19, 2016 09:49 AM
