Sponsored by: CARiD
What is this part? Help!
Old May 8, 2016 | 05:42 PM
Tacoballs's Avatar
Hey guys! I've been lurking here for awhile and finally registered. Thanks for your collective wisdom!
I'm rebuild my 1993 22re 5-speed truck, RWD. Shortly after I pulled the block out/removed the flywheel I found this on the ground: WTF!
Does anyone know what it is? Toyota seemed to think it belonged in there, so I should probably put it back. But where? I'm really screwed on this one. Could have dropped off earlier in disassembly. No threads inside. That it's caked with filth doesn't mean it wasn't in the bell housing - the inside was filthy too. Locating it in the Haynes manual is impossible. Thanks for your help, this is about my only hope.
Old May 8, 2016 | 05:48 PM
millball's Avatar
Kinda looks like a 22re rocker arm spacer??
Old May 8, 2016 | 05:51 PM
92ehatch's Avatar
Looks like the spacer that goes under the motor mount
Old May 8, 2016 | 07:02 PM
Tacoballs's Avatar
It might space the big lower coolant line to the block. I think it was grime-glued to the block and dropped off. I really don't know though.
Thanks for your responses. I can't see where it would be at those locations though. Any other ideas?
Exactly the same diameter opening as this hanger.
Old May 8, 2016 | 07:10 PM
92ehatch's Avatar
There is no spacer there. I'm pretty sure it goes to the mount
Edit. I just checked mine. Oil filter side engine mount top right hole.
CharlesNorris
May 10, 2024 07:45 AM
SpecialScottie
Apr 22, 2016 02:53 AM
shudson248
Mar 7, 2016 06:18 PM
parker247
Mar 3, 2016 03:55 PM
