General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Dome light fix try killed dome, radio and clock power
Old May 7, 2016 | 07:34 PM
weathernaut's Avatar
I've had a non-functioning dome light for years now. Finally started troubleshooting and verified +12V at connector to dome assembly and bad assembly rivets/solder contacts. New assembly was working until my meter probe raked across + and gnd terminals that the connector goes into. Now I only get 0.3V and the radio/clock/enviro panel light are not getting power. Have checked all fuses in interior box. Dome fuse has +12 at the terminal but the connector at the top of the box that has the two wires (b-w and b) going to the dome light that used to read 12V now has only the 0.3V. Any thoughts as to what I zapped?
a
1993 3VZ-E Pickup
Old May 8, 2016 | 12:46 AM
wyoming9's Avatar
Red face
You opened a fuse .
You checked the fuse with your meter ??
If a fuse did not open then you have a physical break in the circuit
Old May 8, 2016 | 04:02 AM
Terrys87's Avatar
Most years the light circuit goes thru the door chime box located just above the steering column. If it is disconnected or removed, the light will not operate from the drivers side but will operate on the passenger side. The box I am talking about is for the years 92ish and older, not sure if 93 uses the box or not. Might want to check that box and see if it is shorted out or something similar.
Old May 8, 2016 | 03:23 PM
I've traced the wires from the fuse box to the top of the A post and they don't connect with anything else so my '93 must be after the chime box you mention. I will post what I find if and when I remove the interior fuse box to see what's happened from the hot fuse terminal to the upper connector.
Old May 8, 2016 | 03:32 PM
Originally Posted by wyoming9
You opened a fuse .
Pardon the ambiguity. I measured 12V at the hot terminal where the dome fuse seats. With 2 different 15A fuses with 0 ohms resistance, I got only 0.3V at the two wire dome connector at the box top. Will report when I dismount fuse box and see what's up.
a
CharlesNorris
May 10, 2024 07:45 AM
admiralnahohkta
Mar 1, 2020 01:44 PM
87runnerhawaii
Jun 8, 2016 12:02 PM
Von551
Mar 11, 2016 11:08 AM
MudWaspSR5
Mar 8, 2016 03:11 PM
