22re leaking coolant from back of timing cover.
I have a 95 yota with the 22re. I put a new top end on it head gaskets ect. I put it back together to notice it pouring fluid from the metal coolant hose on the back side if my timing cover. It's under my power steering pump. I took and made sure my bolts were tight and they were. I amwondering it if has a gasket or o ring that's sapposed to be in between it and the cover. If not maybe my bolts are to long ? I looked all over and can't find anyone that's had this issue any help is greatly appreciated. Can try and post a pic if nessecary.
jayd my tube leaked but turned out it was leaking where the metal strap is welded to the tube,, the one that holds it to the engind (mine has 2) anyway it cracked right in the weld and ran down. looked like it was coming from up top but wasn't.. I brazed mine over. Just a thought. Try a washer under the bolt heads.
i had one that was corroded away on the end, but i was able to slit the hose, and spread it over enough to get a couple of hose clamps on it.
now if i go to the wrecking yard, i'm always looking for decent pieces of those little pipes.
i think that a lot of the corrosion is due to running only water in the cooling system, with nothing to stop the rust.
may be part of front cover gasket . doing timing chain on mine and pulled piece of gasket off of the tube on mine. have yet to get to putting gaskets and new cover back on . simple timing chain is turning into a can of worms .
Same
I am worried that maybe I messed the gaskey up for mine as well. I thought it was just sapposed to use the price of the timing cover. So I have just let it sit there the whole timing chain change has wore me out.
Wondering
did you put it together without any gasket or o-ring? i can't remember what i used there, but if nothing else i always at least use rtv.
Good idea
FS[GreatLakes]: Solid axel power steering boxes
Dexter350k
Feb 25, 2016 07:33 PM
kauaiaxel
Feb 3, 2016 09:18 PM
