fast decision: ’01 Tundra Access Cab or 82' Pickup 4x4 Extended Bed?
fast decision: ’01 Tundra Access Cab TRD or 82' Pickup 4x4 Extended Bed?
To make a long story short, I have to decide fast which to keep between these two trucks:
- 1982 pickup 4x4 extended bed with ~200,000 mi (has an '88 engine with ~100,000 mi.); I recently put in the engine, but have yet to resolve a "clacking" sound coming from engine, so it's not operational. I do not think this is a severe problem, as the engine was working fine before the transfer
- 2001 Tundra Access Cab Limited, TRD, bed cover, with 260,000 mi. This truck has been a wonderful truck. Has no mechanical problems. Slid in ice and hit a guardrail with cosmetic damage (dents, but not structural or mechanical) to front 1/4 panel, access cab door, and bed on passenger side. Also has some significant frame rust localized to 2 or 3 spots on front of frame that would need to be reinforced with welded plates.
I have to pick one or the other. Thoughts on which I should keep?? Thanks a lot for any help, guys.
Logic, reason and not-so-logical factors are making it hard for me to decide! I don't really do a lot of heavy hauling. I have a daily driver aside from these.
Also, I am in Maryland, north of Baltimore. If anyone is interested in either of these vehicles, let me know and name a price. I have about a day or so to start making a move to get rid of one... as in I will find a way to get rid of one...i.e. charity. So, if anyone is, let me know pronto.
Thanks again.
Thanks again.
keep the 82. Tundra are a dime a dozen, and easy to replace. The 82 Hilux not so much. If it were your daily driver I'd say Tundra, but you said you have something that fits that bill, So I would keep the 82, and if you decide later it was the wrong decision, then you will be able to replace Tundra relatively easy. Hell I'd keep them both...
If you have a another daily driver I would definitely keep the 82. Just like It has been said earlier the tundra is much easier to replace. My 82 has tons of sentimental value and I would never part with it.
i wouldn't make it any easier by saying keep the Tundra, would i?
But I believe trucks are supposed to be practical and reliable, so I'd keep the one that is more so. If you've got a pickup that never needs maintenance, and keeps on going, and parts are easy to source, that's the keeper. A workhorse, not a show pony...
...unless that's what you want.
Hope you aren't flat towing the 82 with the rear drive shaft installed.
Even with the transmission and transfer case in neutral the t/c rear output bearing doesn't get lubed correctly according to Marlin Crawler.
You fix one thing on the 82 and some other 35 year old problem pops up.
On the West Coast, I have seen a pittance of Tacomas, not a single Tundra, plenty of 2nd and 3rd gens, and a handful of 1st gens in junkyards, mostly Picknpull chains.
Yeah, 35 year old problems, but with how simple these vehicles are, there are only so many problems you can fix before you've basically restored the damn thing
I say as long as you don't need to tow anything large keep the hills of it has the amenities like A/C you would want in a daily driver. If necessary sell the tundra and use some of the money to fix any potential issues on the hilux. A Weber is a good idea for a daily driver if you don't have one.
I just traded in my 2005 Tundra 2WD Double Cab with 160,000 miles for my 2016 Tacoma - definitely didn't get what I thought that I would for it. Ran like a champ, but it was a "high" mileage 2WD truck that was beat up a little bit so the used market isn't great for it. I'd hate to say it, but if you want to drive a reliable truck, I'd go with the Tundra. My 83 pickup is super reliable, but it is basically new after I restored it - your's... not so much.
Also, there was a recall on the frame for your Tundra. I'm not sure if the recall window has closed, but Toyota was re-coating or replacing frames if the corrosion damage was extensive enough. Might be worth sliding by the dealership to see what they might do.
Bajawfo
Dec 8, 2015 04:14 PM
4rollin
Dec 5, 2015 07:17 PM
