Cody91 93 4Runner build up
So I'm back in the Toyota game !!!!
Little background.
When I moved from Idaho to California 4 years ago I was only able to take one rig with me and so I had to sell my 88 runner and I was kinda bummed. After I got back I sold my 91 single cab to get a truck with more room so I got a 97 runner did a little stuff to it but under all the undercoating it was rusted to ˟˟˟˟ so I sold it and got a 04 Subaru WRX drove that and got tired of the heavy ins bill so I sold it and got a tow pig 01 Ford F-350 crew cab long bed 7.3 diesel. Last summer I picked up a Subaru Legacy for 500$ put a few $ into it and had a plan of boosting it but I was missing having a Toyota so put it on the good old inter webs and traded it for this 93 4Runner sr5
Ok so on to the 4Runner
1993
3.0 3vze
5 speed
305k miles
Runs and drives*
Little background.
1993
3.0 3vze
5 speed
305k miles
Runs and drives*
Plans
Plans for the Runner
Have Parts
Parts on the Way
Need To order
Front lift
Parts on the Way
Need To order
PARTS LIST / Install Dates
Front lift
SAS
Axle from a 85
TG Front Spring hanger kit
Rebuild With Marlin crawler seals/bearings (Done)
TG Ubolt Flip kit
TG Supper Flex 5" Springs
Shock Hoops
Longfileds
Bilstein 7100 Short body255/70 14"
5.29 Reman from CoresWest (Done)
Longer splined drive shaft
Steering / Brakes / Tires
TG High Steer
TG Pitman Arm
97 Tacoma Rotors (Done)
Ifs Hub bodys turned down to fit Tacoma Rotors (Done)
Longer Front Wheel Studs ( Rear studs from a 93 4runner ) (Done)
V6 IFS Brake Calipers
LROR Backing Plates (Done)
Wheel bearings (Done)
Extended brake lines
Steering Stabiliser
35/12.5/15 BFG KM2
Rear lift
Leaf spring conversion
Chevy 63
Disk brake swap
Locker ARB air locker
5.29gears
Bilstein 7100 Short body255/70 12 or 14"
Mods
Onboard air + tank
CB
Power inverter
Rear bumper W/ Tire carrier
MORE TO COME
Got to spend a little time with the runner the day after i got it home.
The dash was not bolted up took it apart and cleaned a little. So i got some bolts for it from my toyota bolt bin and replaed them.
The inside is dirty and stinks so some cleaning is needed
on my drive home i found
Clutch is on its way out
Driver mirror is Broken
need all joints replaced in the front end
Windows need some help they are slow
Rear window switch does not work
Left rear door outside door handle does not open the door
funky alarm system
Fan clutch is broken and about to let the fan go
Wipers suck
On the plus side
Service Records from day 1
AC/Heater Works Good
Wired for sub and amp
4X4 Works
Well Picture Time !
funky alarm system
Wipers suck
On the plus side
4X4 Works
Well Picture Time !
pics form the day I got it
2/23/16 Update
i got my Axle over the weekend and got some time to work on it to day not much but i got some paint on it as it was bare and had some rust on it
waiting on my rebuild parts to get here but i will start on to tear it down at the end of the week and rebuild when the parts get here
Its a 85 axle with Stock shafts, 4.56 gears and High steer
Going to do the Steering stop mod
Pic Time
yeah but its just a number its not my DD or only truck so its just gonna be a toy and its all rebuildable
It ran good drove 60 miles home and it has had a new engine 100k miles ago cost $5800. i have all the service records from day 1
and i traded a Subaru Legacy With 336k, it had more in wheels and tires than the car was worth.
i think i got the better end of the deal.
Update 3/06/16
Well did not get as much done as i wanted to but did make some progress
Had to have my puppy spayed this weekend and put in a new entry way floor.
But i did tare down the axle and found some stuff i was not happy about
when i get it i was told it was just rebuilt ready to go. But when i stater to tear into it it was not looking good.
I did not like the way the brakes were set up. i have a plan for them that runs 97 tacoma rotors and 93 IFS calipers, Hub assembly and wheel studs from the rear axle
Also found the Trunnion bearing's to be damaged and and some rust and nasty fluid in the housing
and no gaskets any were on the axle just RTV
also the wiper and felts are damaged
So i had to order some parts they will be here in the middle of the week
NO Snap Ring on either side
Miller Locker
PIC TIME !
Miller Locker
Small Update 3/8/16
Well the runner is mine now was at the DMV for 2 1/2 hours but its done. :doom:
I'm want to get the runner to my house soon its at my buddy's house about 1 1/2 hours away from me so i can't really work on it yet. But i can still work on the Axle.
IF any one knows were i can order some internal free wheel hub parts let me know.
A few parts came in today.
Spring hanger Kit
Steering Box relocate kit
more parts coming in the rest of the week.
Spring hanger Kit
Update
Well got a little done on the runner this last 2 weekends
The Fan clutch was damaged so got one from my buddy and put it in had to replace a few studs as the ones were damaged from when the last owner put one in.
Fixed the Tailgate window Switch and Lock Switch.
Went to pick&pull and got a few parts
New driver door mirror & trim peace
dimmer knob
Oh $h!t handle for driver side
clutch pedal cover
Also got a little more done on the Axle
Used the hosty at work to clean the housing out.
knocked all the bearing and races out of the hubs and ground them down to fit the 97 taco rotors
and did the steering stop mod
Started the Rebuild but had to do some stuff this weekend so i did not get as much done as i would like
also got
LROR Backing plate kit
TG Rock Rings and new hardware
dimmer knob
clutch pedal cover
also got
Well not much has been done in the last few weeks
im hoping to get the axle under the truck in 2 weeks. i will have to put the axle in with no shafts or 3rd member.
i had a change in plans i was told the axle had 4.56 in it and i did not check so now i have to re-gear and im running short on funds so its gonna have to wait for a wile.
but if i can get the axle under it than i can finish up the brakes and and do some cleaning and free mods wile i build funds back up for the gears and locker.
This coming weekend im going to
Clean the carpets
install new mirror and trim
wire up the radio
paint some of the trim black
remove rear bumper and tow hitch
Clean the carpets
wire up the radio
Small Update 4/22/16
Got a little done Last weekend
Carpets cleaned
washed the rig
Removed rear bumper and tow hitch (It does Not Sag as much in the rear now)
Removed Factory Spear tire Date code said 1992 not much help when its flat and old.
New
plugs,cap,rotor,wires
Than me and my buddy were going to hit up some trails and had a little problem
So i did the Cap,Rotor,Pugs & Wires also Adjusted the timing to 12º
Ran it up a 7% grade did good 60mph the hole way before i was lucky to get to 50Mph
so i stopped at the gas station to wait for my buddy we toped off i used 91 and a bottle of Lucas fuel treatment (the small one). we headed up another hill on the freeway and thats when the check engine light came on and it had a bad miss.
Pulled over so i could check the wires and plugs they were all good put the timing back to 10º and it was still there. not noticeable at idle but under any throttle it has a miss. Checked the code only one was Code 52 KS witch i had before this happened.
limped it back to the shop and checked all the plugs and replaced them once again with NGK V-power (OEM replacement) Same thing
Put the old wire,cap,and rotor back in and it was worse now it has a miss at idle.
thats when i gave up for the night and had to head home.
i was thinking about it over the week and think one of the injectors has failed/clogged.
maybe the injector cleaner broke some junk up before the injectors and it clogged the little screen in the top of the injector.
if any one has some input on this issue let me know.
any way i got a compression tester but left it at work
im also going to go pick it up this weekend so i can work on it after work not just on the weekends..
PIC TIME !
Puppy Was Ready to Hit some trails up!
All ready to pick here up !
Carpets cleaned
washed the rig
New
PIC TIME !
Update 5-6-16
Well i has been a crazy few weeks but have got some done on the runner
Got it home !
Added some sticker
painted the front bumper black (bed liner)
found out that my miss is coming from a bad injector
my #2 injector is open so it was not firing
got 6 newish injectors from a buddy and put them in but i did not get new O-rings so when i put it all back together i had a bad fuel leek.
Tore it all down again and did the PCV valve, new Air Box AFM, TPS, Plugs, Wires, Cap, Rotor.
was waiting for the O-ring to come in and they just got here so I'm Going to install them this weekend and get some other little this done..
WELL PIC TIME !
Tight Fit but she fits !
Also helped a buddy work on his 3.0 to 3.4 swap
Got Some Epic NEW Stuff For Work !!!!
135$ cant pass it up
and my new baby !
Got it home !
Added some sticker
WELL PIC TIME !
and my new baby !
Update 5/28/16
A lot has Happened in the last few Weeks
Got the engine all put back together no fuel leeks.
Took it out for a test drive and it did good till i got the dreaded code 52 again now it comes on as soon as i hit 1600RPM so i guess i have to find out if its the wiring from the ecu to the KS or the piggy tail. Thats for a later weekend.
So i was tired of have to do all my welding at work witch is 60 miles round trip so i got my self a Lincoln 180 of the good old craigslist. came with a cart,gas, and flux core wire.. but i got it all set up to use .035 solid wire with 75/25 argon/co2.
So now with having the welder i had to replace one of the spring perch's on the axle and add my gusset. got that all done and put in my new 5.29 from CoresWest and finished assembling the axle.
A Little more Grinding for the caliper to fit just right
So now there is only one thing left to do Remove the IFS !!!!!
No Going Back Now!
Well there is no going back now! IFS is out and frame is ground down.
i did not have a plasma cutter or Oxy torch so my only way was a grinder with a cutoff wheel and a Sawzall..
i used 5 torch blades and one diablo blade for the sawzall & 6 cutoff wheels and 2 flap wheels 80/40 grit.
Took 5 hours to cut and grind it all down and make your arms fell like jello.
getting ready to cut the holes for the frame tubes and mount the hanger.
here is a few pics from the day of cutting.
Also got a new air compressor from HF Was on sale so i could not pass it up.
Little Help from my buddy Brad
Big update !
Well i got a lot done in the last two weekends but not enough to be able to take it for a test ride.
frame tubes are in spring hanger is welded on and the axle is bolted to the springs.
got the pitman are off and the new one on. only broke the tool one time not to bad lol
Just need to finish up a few things
Than i can start on the A$$ end so i don't have the So-Cal lean going on haha
Well PCI TIME ! ! !!
- Weld motor mount plate
- Shock's and Hoops Welded
- brake line's and New pads
- adjust steering stops and high steer
- fill the diff with gear oil
- install diff breather
- make a drive shaft
