Name that sound: clicking from the rear, inside
Old Feb 1, 2016 | 08:42 PM
tj884Rdlx's Avatar
I just put the hard top back on for the first time in years. What are all these noises?!
OK, one i recognize: the tailgate hinges are slapping around.
Q1: should there be bushings to keep these quiet?
But one i can't locate, because it only does it when i coast, in gear, around 3k rpm. It sounds sort of like my loud clicking wiper delay relay. But it's coming from somewhere behind the rear seat.
Q2: What's back there that would make a clicky- creaky sound every time i let off the gas and coast at higher rpm? Any relays in the rear quarters?
It could just be a harmonic vibration at that rpm. But i can't get in the back of the truck to listen, and drive it!
Or can i....
Old Feb 2, 2016 | 01:49 PM
highonpottery's Avatar
If you just put the top back on, I'd suggest loosening all the bolts, shift the top a little bit then tighten them back down - perhaps something was out of alignment and just needed help? Is your weatherstripping seal intact?
As for the tailgate hinges, try these:
https://www.yotatech.com/forums/f116...runner-247176/
https://www.yotatech.com/forums/f116...rattle-249341/
Old Feb 5, 2016 | 07:29 AM
tj884Rdlx's Avatar
No, man, the top isn't MAKING the noise, it's made the interior so quiet (compared to several years with only a Canback) that i hear noises from other places in the truck that i just didn't notice before! =)
It really is nice n snug in there now. Heat is sweating me out in minutes!
I'm wondering if there's any relays in the rear compartment that could be making a clicking sound because it's getting old and not switching cleanly. Like my wiper delay relay does down by the fuse box. I didn't think there was any back there.
Oh but thank you for the link to the thread with the tailgate part numbers. I remember having those, guess they finally bit the dust!
Cheers!
Old Feb 5, 2016 | 08:07 AM
Not 100% sure but I don't think there's any relays in the rear. When's the last time you greased your leaf spring bushings? I've had dry leaf bushings make a click-like sound when driving, it was the front ones on mine. I also see you have a BL - have you ever re-torqued the fasteners?
StangBanger
Jul 23, 2018 06:36 AM
Old83@pincher
Feb 20, 2016 04:24 PM
Grego92
Feb 6, 2016 12:10 PM
Tfalley
Feb 2, 2016 11:06 AM
Mikkydee
Jan 27, 2016 03:23 PM
