Possible to add Rear Diff lock to 2wd 93 t100 truck?
Old Dec 28, 2015 | 07:48 PM
oldspice's Avatar
Question Possible to add Rear Diff lock to 2wd 93 t100 truck?
Hello, I have a 93 t100 truck that absolutely sucks in any sort of off road situation. I am wondering if its relatively easy or even plausible to add a rear diff locker to the rear, and what components I would need to find.
I have a 4wd VW with front / rear diff lockers and I noticed 90% of the time in off road driving all I need is the rear two wheels locked and not even the front engaged... I would love to make my truck more capable off road.
My other question is what do you think is more important, 4wd or all terrain tires?
I currently have road tires on which is obviously a factor but im not sure what would be more a factor.
Old Dec 29, 2015 | 02:06 AM
Terrys87's Avatar
It is possible to add rear diff lock to a 2WD, just depends on if you have the ability to do it. I looked at a 96 runner that was two wheel and had the rear diff lock in it.
4WD would do better then all terrain tires any day.
Old Dec 29, 2015 | 02:16 AM
oldspice's Avatar
I will likely hire someone to help.... just need to know what kind of components to search for...
that question is 2wd locked with road tires better than unlocked 2wd w/ terrain tires.
Thank you.
Old Dec 30, 2015 | 11:49 PM
wyoming9's Avatar
Red face
Since your talking T100 swapping a complete axle housing from a Pick Up with the Elocker won`t work.
Was the E locker a option for the T100??
Then Off Road is a very large term.
I had 2wd trucks that would be stuck on the slightest incline on wet grass.
Good Tires and @ 500 pounds of weight just in front of the axle will work wonders.
Buy a 4x4 and be done !!
Old Jan 19, 2016 | 01:05 PM
oldspice's Avatar
Thanks for the info.
Old Jan 19, 2016 | 01:06 PM
oldspice's Avatar
anyone else ever done this or know how?
Old Jan 19, 2016 | 03:53 PM
v_man's Avatar
I'd just get a Lockright auto locker , easy install , maybe $350...
Joa
10
Nov 5, 2015 10:53 PM
83
11
Oct 20, 2015 07:22 PM
FRANCOARMANI
Oct 19, 2015 07:33 AM
skouba
Oct 10, 2015 05:15 AM
JimiJams
9
Oct 8, 2015 12:15 PM
