Just installed a rear air locker on my runner. When I turn on the compressor it works as it should but when I hit the locker switch all of the air blows out of the exhaust port of the solenoid and doesn't engaged the locker at all and the light on the switch doesn't light up. I found in an ARB operation manual it is a bad solenoid. Has anyone had any experience with this? It's brand new which is a little frustrating. Thanks
After I researched more I found out it may be mounted backwards.. but I have the side labeled 1 into the compressor and side labeled 2 into the airline. The only other think I can think of is that it's because I mounted it upside down for space saving reasons but I have found on other threads that it should work fine mounted upside down?
Port one goes into compressor. Gear oil coming through your air line usually means a clogged diff breather. Did you try calling Arb? They do have a tech department for this reason.
I flipped the toggle switch cover around and now it comes on and works.
I YouTube'd the sounds and I believe it is working correctly. I hear a very faint click in the differential when I engage the switch. The light comes on and stays on. And when I turn it off it exhausts the way it should.
So I think the problem is solved but do have a couple other questions..
Is it normal for the compressor to turn on when I hit the locker switch to fill up the airline?
I have a Trail-Gear Creeper diff breather, would that cause any problems with the possibility of there being some gear oil reaching the solenoid? I'm just not sure if the air locker really needs and open hose for it to work well..
This is Trail-Gear's Creeper diff breather that I am using.
The compressor doesn't turn on every time I turn on the locker switch. I put Teflon paste on everything, guess I'll go around with some soapy water to spray on the connections.
EDIT: I did run the airline probably the longest way to the back. The compressor is mounted under the hood on the driver side near the brake and clutch reservoirs. The airline I ran across the engine bay then straight down the passenger side. I did this because running it down the driver side puts the airline way too close to the exhaust downpipe. I kinda thought it may be normal for the compressor to turn on to fill the airline when the locker switch is engaged, but you said it's not so..
I have the ARB HD compressor and F/R lockers. If the rear is disengaged it releases the front too.
Just using the rear, the compressor turns on 2 times for every 3 times I engage the locker.
Mine has been great for 3 years now. Operation is the same today as the first day I installed it. Ambient temps change it a little.
I mounted the compressor under the hood on driver side fender. I routed the air intake trough a hose that goes into the cab where the filter attaches. This might help if you go into water.
Great info, thank you guys for helping me out. Glad I finally have my air locker figured out and can't wait to get the gears fully broken in and get on the trail! Snow wheelin is calling my name lol
