solid axle birfield re assembly
Hello good people .
I'm new around here, but heard good things about this site so i decided to try here .
I've almost completed the rebuild, ratio swap and ARb's on my LC105 (which is a solid axle 100 similar to the 80) but got stuck after disassembling my birf completely. I'm not sure which way the inner and outer parts and balls should sit.... the inner ring is slightly more tapered on one side and stuff like that....
I've spent hours searching the forums here, but failed to find a description of the inner parts of the joint . most threads are on replacing the entire birf or removing the shaft . BTW the FSM has nothing to say about it .
help would be greatly appreciated.
