General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
94 toyota pickup ac compressor ground wire help
Old Nov 4, 2015 | 05:12 PM
alva22re's Avatar
I removed my ac from my 94 toyota pickup and i wanted to know if i can remove the ac compressor ground wire or does it to to be mounted somewhere
Attached Thumbnails 94 toyota pickup ac compressor ground wire help-20151104_180709.jpg   94 toyota pickup ac compressor ground wire help-20151104_180717.jpg   94 toyota pickup ac compressor ground wire help-20151104_180725.jpg
Old Nov 4, 2015 | 06:10 PM
millball's Avatar
Thats not the AC ground wire, it's the main battery to engine ground.
It must be solidly connected to the engine block
Make sure that everything is clean and shiny, and bolt it back to the engine near where you found it fastened before. You may have to find a shorter bolt than what was used with the AC compressor fastening.
Old Nov 4, 2015 | 06:34 PM
alva22re's Avatar
ok thanks and can it be mounted anywhere in the block.
Old Nov 4, 2015 | 06:59 PM
millball's Avatar
Anywhere it will reach and still have enough slack to flex when the engine moves a little.
Old Nov 4, 2015 | 10:07 PM
alva22re's Avatar
ok thanks again
Old Nov 4, 2015 | 11:31 PM
wyoming9's Avatar
Red face
Might not be a bad time to get a new cable of a larger diameter while things are apart.
mbomberz1
Apr 29, 2023 09:58 AM
Jonny246
Oct 16, 2015 02:50 AM
PT3
3.4 Swaps
Oct 13, 2015 09:39 AM
RoadRage
Oct 9, 2015 07:43 PM
1985 4Runner
Oct 5, 2015 06:20 PM
