Weird idle up
Old Sep 7, 2015 | 08:56 AM
Tacoma1313's Avatar
Weird idle up
2004 3.4 L tacoma 80xxx miles
I have an idle up even when the a/c is off.
Is this normal? The only way to stop it is shutting off the fan. Is the truck supposed to idle up w/o a/c for fan speed increase for cooling?
Thanks in advance.
Old Sep 7, 2015 | 10:51 AM
wyoming9's Avatar
Red face
Is the engine at operating temperature ??
Do you have the Defroster on ??
Sure the AC is not on??
Old Sep 7, 2015 | 08:56 PM
Tacoma1313's Avatar
Operating temperature, no defroster, and the AC is off. The AC button is not lit.
It is the weirdest thing. I disconnected the battery and let the ecu reset and it didnt do it for a few weeks. Then it started doing the non AC random idle up again.
The idle up is identical to the AC idle up.
Old Sep 7, 2015 | 11:39 PM
wyoming9's Avatar
Red face
Does this cause the MIL to trip ??Any non normal idle most often will cause a PO505 code
Have you looked to see if the compressor clutch is engaged when you turn the fan switch on??
Old Sep 8, 2015 | 08:19 AM
Tacoma1313's Avatar
No codes i checked with a diagnostic reader.
How do i check the compressor clutch?
I assume it is on the AC compressor somwhere by the belt pulley?
Old Sep 8, 2015 | 01:27 PM
wyoming9's Avatar
Red face
It is on the front of The AC compressor
When in it gets system voltage the electromagnet pulls in allowing the belt to turn the compressor .
Quite easy to see the difference.
Blamalam
Mar 12, 2022 07:34 AM
Marsheen
Feb 17, 2016 12:29 PM
Sarcazmo
Aug 15, 2015 08:22 PM
accuracy
Aug 4, 2015 08:05 PM
icentropy
Jul 14, 2015 10:23 AM
